Oil reservour problem
I have a 1990 Yami 150 The oil tank on the engine is fine and the motor takes in the oil. The problem is that the auxiliary tank is not supplying oil to the tank on the engine. I have changed both the toggle switch and the pump and motor on the auxiliary tank. The tank on the engine runs down and the buzzer comes on. I have checked the connections for corrosion. What part calls for the oil to transfer and how does it work? Any ideas as to what is wrong?
Please reply to tfurn1@yahoo.com
SparkieBoat
Re: Oil reservour problem
I am a premix guy..I just plug those lines off..but I am sure there has to be a sensor in/on the tank that would call for oil. take a look at a parts diagram, should show you.
KDAVID1
+1. Best insurance for a motor--premix--it's way too easy and will save you THOUSANDS
