Engine: 1993 50 hsp. Evinrude
I noticed recently that oil is leaking from around the primer bulb on my oil tank. The primer bulb has 2 metal clips on each side of the bulb. One clamp is on the hose and one on the bulb each clamping to a nipple on each of the bulb to keep everything connected. The bulb will rotate around the nipple on tank side and the apparent cause is the loose clamp on the bulb. This is where I've been seeing a very small leak. The obvious solution would be to get a hose clamp or one of those plastic crimp types and tighten up the connection. Before I do that, I thougth I might want to just replace the hose on the tank side because it is that old 1990s vinyl junk. The hose on the engine side is the good rubber stuff.
Now..finally the question.... The hose that I'd like to replace runs from the bulb into the oil tank and is only about 6 inches long before it goes into the tank. I'd like to know (without taking apart and finding out for myself) what type of connection is inside the tank or at the fitting. Is this something that is easily replaceable or am I going to run into something that I'll have to replace more than just the hose. Before I tank the oil pickup assembly off the tank to find out, I figured someone would be able to tell me what I'll run into.
Thanks!
Thanks!
