if you have passages blocked, the water temp will be higher
normally if a passage is blocked, its the thermostat passages or the exhaust manifold passages. in either case, it slows or stops the cooling water flow, causes an overheat and with lack of water exiting the system in the exhaust, you also burn up all the rubber pieces in the exhaust system.
