Oil to fuel ratio
jjhjrcmh
I am removing the external oil tank on my Evinrude 200 hp 1998 and was wondering what the proper oil to fuel ratio is.
Mas
Re: Oil to fuel ratio
I do not see why the ratio would be anything other than 50:1 TCW-3
MAS
Chris1956
That is normally a very good oil mixing system (4 wire OMS pump). Why are you removing it?
R.Johnson
The usual reason is that a friend, of a cousin from a previous marriage, once had a piston go bad, and his mechanic told him to. The reason being, they were trouble from day 1, and they still are.
dingbat
The oil is mixed in the OMS then sent to the carburetors. A failure would result in multiple, simultaneous cylinder failures. The failure of a single cylinder was most likely a problem with a carburetor.
FWIW: I have the same motor. Over 2000 hours on it now. A couple of electrical problems in it's lifetime but nothing involving the oiling system.
Replaced the OMS as a prevent measure @ 1000 hours.
cjd
In keeping with the oil to fuel question, I have a 1988 6 HP jphnson that calls for 100 - 1 (written on the engine itself) while my brothers 6 HP evinrude (1994 I think) calls for 50 - 1
100 - 1 scares me. any downside in running 50 - 1 in the johnson?
Vic.S
You should be running it on 50:1. See the link I posted earlier.
OMC flirted with 100:1 mixtures around 1985 and for a few years after but later advised that they should in fact all be run on 50:1. The decals referring to 100:1 should have been removed and the owners manual amended too.
50:1 under 6000 RPM, use 50% more up to 6500 RPM, double oil after that (25:1). Or: run the Evinrude E-Tec synthetic oil at 50:1 at any RPM.
jjhjrcmh
Dueto failure, Last 2 times oilt to fuel ratio is about 10:1. Oil side leaks bad and I believe it is original. I whish oil side could be rebuilt. It is a good system but when it fails it causes excessive oil use. I will just mix in tank for now and look to buy a new one at some point in time. I am new to boating.
