oil under cowl
i have a 1986 mercury 25 xd why is there oily residue on everything under the motor cover obviously somethings leaking but what can it be
KT64TM
Re: oil under cowl
Could be the upper crank seal, or a loose/broken crankcase vent line
Re: oil under cowl
ok i was looking at the motor and didnt see either of the things mentioned above were would these two parts be located sorry for the stupidity
Faztbullet
Re: oil under cowl
There are 2 small rubber recirc lines under carb, check to see it they have came off or split.
