Oily film in my hot tub - Possible Source ?
roscoe
Not sure where it is coming from.
We cleaned it out, added fresh water.
Turned it on to heat up over night.
Oily film was everywhere when I checked on it in the morning.
roscoe
Re: Oily film in my hot tub - Possible Source ?
Here's a photo.
What do you think?
Kiwi Phil
Pleased you put up the picture roscoe....I was going to make another suggestion!
Cheers
Phillip
tashasdaddy
you are suppose to shower before getting in.
kenmyfam
Try using synthetic 2 stroke oil !!!
angus63
Capt. Joe Hazelwood?????
roscoe
no exxon employees here.
I'l try the synthetic.
NoKlu
I heard they were banning 2 strokes on some lakes for that very reason. A good 4 stroke or a few electric trolling motors will clean that right up.;)
salty87
you sure that isn't chum? toe count time
LadyFish
I would wager a bet that its women's body lotion or suntaning oil/lotion.
wajajaja02
clean the filter, , run the air jets, if it foams, it body oil that cause the foam, a cap full of defoamer will break up the bubbles but only hides the fact that the water is "dirty" . google spa maintenance, spas can make you sick.
I once a month drain my spa, scrub down the tub and refill, easier than trying to sanitize and balance the water, its only a 1k gal or so of water.
jakebrake
i'd bet with ladyfish. that stuff wreaks havoc on swimming pool filters
QC
I think it may be due to lugging, what's your WOT RPM?
wajajaja02
one way to eliminate the oil is to shut it off and overfill it and let it flow over the top of the tub, oil floats over the dam.
I fill mine with domestic hot water,cheaper than heating it with the spa heater when its cold.
gstanton
Ummmm... I think trim tabs would take care of it!
jay_merrill
That's cause you're running the early fifties 16:1 mix motor! Now, if you were running an ETEC, you'd get more torque in the pool than a Yammy 4-stroke, and the pollution would be fine. Besides, I hear that XD-100 gives your skin that youthful look that is so desireable to women!
Don S
My Gawd Man!!!! That is an OLD Johnson. Those things were rainbow leavers for sure, usually more of a slick, as you may have noticed.
This is exactly the reason for all the environmental changes and why 99% of the outboards are now 4 stroke.
Get with the program and upgrade to the new 4 stroke outboard for cleaner water. Keeps the Hot Tubs a lot cleaner.
OR, keep your head above water.
Tyme2fish
Roscoe, I am surprised by your ignorance. Any true redneck knows to use a 65 pound thrust ELECTRIC trolling motor to avoid oil in the hottub.:D
j_martin
The funiest part of this thread is noticing the posts put up by folks that didn't notice the outboard motor.
LMAO
wajajaja02
I didnt see the pic (attachment) until late last night, funny
