ok a noob question
bigmcgiv
Re: ok a noob question
can you use it on bolts when you replace a transom or use silicone
Woodonglass
I'd recommend 3M 4200 Marine Sealant for installing bolts and other hardware into a transom. I never use silicone on a boat.
GA_Boater
WOG got you covered on the Gluvit and Coat-It. Both are good and as Wood said, Coat-It is a wee bit cheaper. One thing to watch for if you use them and there is any sun exposure, they have to be painted over. UV destroys the stuff and under decking is no problem..
You'll be adding a few more words to your vocabulary as you move through the resto. :)
