Re: OK to use a deep cycle for starting & fish locator?
Just to let you know......I took my boat out and went fishing yesterday. I was apprehensive as to how my new battery hook up for the electric start and locator was going to perform. Remember that I just hooked up the leads for the electric starter and locator directly to the freshly charged deep cycle battery. I used my new electric starter and fired up my Merc. Amazing. Let it warm up a bit, then turned on the Humminbird locator. The locator has a volt indicator on it and I was paying a lot of attention to that reading. It was a 1/2 mile trip up to the dam where I was going to fish so I would be able to get a good idea of what was to follow. The (Wisconsin) river being very shallow this time of the year, I was not able to get up much speed because I was worried about hitting rock obstructions in the water. So I put her in gear and slowly motored north. I watch the volt gauge climb upwards toward of 16 volts !! HOLY COW ! Talk about pushing out the amps. Good or bad ? I must have started the motor about 10 times, moving around looking for the walleyes. I left the locator on for 5 hours straight. The voltage stayed between 12.4 & 12.7 or so. Every time I moved, I always watched the volt meter. The volt value would increase each time I started the motor, even though I would just hardly give it any gas to move to another location. After 5 hours of unsuccessful fishing, I headed back to the launch. 2 hours later, when I got home, I was anxious to check the battery status, because I was sure it was in need of a good charge. Well, to my surprise, my battery tester stated that the battery was fully charged and did not need to be charged !! I double checked it again...it was true. Sorry for the long post......
