emoney
- Joined
- Jul 19, 2010
- 2,551
So, I've got great water flow thanks to the sticky and subsuquent change
of the impeller. Everything shifts fine, and it starts well. As a matter
of fact, it SEEMS to run ok at idle/low speed. However, I may be allowing
for a lot of leeway, as my other outboard is a 'Rude 9.9 with no insulation
under the cowling on my sailboat, so it's kinda loud.
It does seem to be a 'little' rough.
The biggest problem is, I don't have any speed at all? I know there needed
to be a main idle jet adjustment, and I'm not sure I've got that correct yet,
but it seemed to be a little on the lean side before I adjusted it.
What do I look for next, as to the low power when running issue? Also, how
do I really know when I have the air/fuel mixture right, and would this cause
the engine to have no top end power? I've got my trusty manual, but I'm
not sure what I'm looking for/at, so somebody direct me please (hint, hint
Frank & Jerry). Nothing got abnormally hot under the cowling now that I've
changed the lower unit. Keep in mind, it starts well, idles on it's own, and
goes forward and reverse? Also, if somebody suggest 'check
spark', please clarify that
