Re: Ok you old salts...Merc question
the 1500ss inline of the late 70´s was running bigger carbs,bigger reeds and larger transfer ports and boost ported pistons, also had high dome pistons and somewhat higher compression than most the rest of the inlibes.
it also came apart more often as it tolerated NO subsystem degradation what so ever. however when they was good they was good,
had a friend that regularly spun his at 8500.
he used a pair of OMC CD amplifiers and the old style duel point kiekiefer distributor.
TRW single ring pistons and special custom built reed blocks.
at the same time another friend was running a highly modified 75 3cyl jonnyrude block on a homemade midsection and homemade gearcase with a homemade prop.
no flywheell and a homemade hot head with a homemade operator adjustable expansion pipe for exhaust.
they used home made cylinder finger porting and modified single ring TRW pistons.
ign was a custom ground cam indexed to the crank key and 3 sets of points fireing 3 battery CD amplifier boxes and 3 ign coils.
while actually dialing it in for max speed the lst race Ron ran he set the altidude record on the nnsmond river and almost died, the hul was rebuilt and sold. Ron still has the engine.
his estimated speed at the time of becoming airborne was 115MPH. not bad for a 3cyl on a 13ft plywood hull at 9200 RPM.
he did find out that day why when ejected he always ended up back in the boat. seems as the boat continued horizontaly he slowed down,until the boat went verticle and he reentered it. thats what hurt him.
he said he got to watch the closing with the hull in slow motion.
then went through the front deck head first.
cant beat a bell toptex
but yes the inline 6 merc went through some amazing technology changes from the mid fifties to the late 80´s.
some good others not so good.
my opinion of the hall effect trigger used on the thunderbolt system is not worth discusing.
the funniest of the six´s was the old dock busters
. had a customer with a pair of them for years.
hated them.
