BIGSTRIPER80
- Joined
- Jan 22, 2008
- 48
Okay guys -
I posted earlier n the week that when my mechanic gave my boat a tune up, and relayed the bad news that they found a slight amount of water in the oil when the changed the oil. He told me the only way to see how bad it is, is to run for a while checking the oil every 10 mins or so to see if the level changes or it get's milky. That was last saturday. My motor is an 88 Mercruiser 4.3 alpha one.
Well to make a long story short, it rained for 3 days straight earlier this week and my tarp broke and the a ton of water got into the boat and the engine area. The boat had a fresh tune up with oil, So I went out this morning to start it up and got the motor running for about a mintue very smooth. Then it died out and I couldn't get it started again. I checked the oil and it was completly milky with water in it white color.
So I decided to change the oil to ensure I wouldn't do anymore damage. Chnaged the oil from the bottom of the pan, and put a new filter. I was in a bind so I got some 10w30 and a regualr auto oil filter for the 4.3.
Went to try and start the motor and it would only turn over roughly 1 -2 times and then would stop. Tried to get it going for about 10 mins and could get it to fire up with only 1/2 rotations before going dead. My question is any thoughts? Battery? Also, how did that much water get in the oil from the rain? What do I need to do now to get it running. it's got new filter and oil.
you guys are awesome. This is my first 4.3 i/o so i am learning and taking things a part as i go.
Thanks,
Thanks,
