Jmorrell588
- Joined
- Jul 20, 2002
- 61
***Evinrude 1989 VRO Crossflow 2 Stroke 4 Cyl. Note - the powerhead on the motor mount is a 97 powerhead* Nothing has changed except for a few updated features since the 89' model****<br /> Okay, if you have followed along on my last post of taking my motor apart to rebuild it (due to a bad piston and cylinder), I just got the block off the body and tomorrow I will open her up and clean it out good and put the rod caps back on once I take the rods/bearings and piston out of the cylinders. <br /> I have decided that since this is a big task for me, I want to go ahead and bore out each cylinder while I have it out and open. I figured that I have learned a great deal on how to properly mantain a motor since I now know what caused this problem. I owe the knowledge to this site and how to care for a motor and make it last. But only after something went wrong, as in most cases with everything in life.<br /> So, the question is this, is Napa a okay place to take my cylinder's to and have them bore it out ? or, does anyone have a place or know of a place in the Atlanta region that they trust, where I could take this over and have it bored? I am willing to travel 70 miles or so.<br /> I have labled every single wire, every bolt has been put back into the holes and the other end is cable tied to as not to loose them and I do not have to worry about labling them since I have then cable tied and they cannot come out. I have taken over 50 pictures of removal steps to insure I know where all pieces go back to. Not sure if this will help or not. On the shift lever, I even cabled tired them in the exact motion that they where in. All I have to do and just put bolt them back on. Same for the spark advance lever. Thought something tells me that this will be needing adjusting, but will cross that bridge when I get to it. I have noted that some bolts will be replaced from reading the manual, so I colored them red (so I know that the color means replace.) but installed them back so I can remember where they go when I get the new ones. <br /><br /> Jimmy
