Suprathepeg
- Joined
- May 25, 2015
- 259
So I picked up this old 13'-3" hull. Its been sitting in a field for 20 years. The bad news is its a mess transom is shot, no controls, no motor etc. It has a gas tank but its metal and its had fuel and maybe water sitting in it for 20 years. The good news is its a super simple design the two halves just clam shell together with pop rivets, the floor is the bottom of the hull so there are no stringers or floor to replace, the transom is literally just plywood glued to the hull. So here is my plan. 1. split the hull and remove the old transom wood etc. 2. glass in a new transom and some new seat bases. 3. install controls. 4. strip and repaint the upper hull (bottom is pretty nice) 5. some sort of stereo The only gauges I"m planning to run are tach and temp. Here are some of my questions so far: 1. How should I power it? In its past life it wore a 40hp. I think I can get my hands on a merc 50 or a merc 75. The 50 is probably a better match for this small hull but I wanna hit 50mph so how should I prop it? 2. Would this be a good boat to swap in a jet ski power train? The benefit I see with this is that it would be a great shallow water boat and it would probably be lighter than a full outboard. It would be a lot of glass work but probably not too bad. 3. Trailer suggestions? 4. I have a plastic outboard tank, should I try and salvage the existing steel one or make use of the plastic one?? 5. Seats? This thing used to have two back to backs, I think I wanna make it a 2 seater. I was thinking of using small buckets like go cart seats but I'm 230lbs so it would have to be big enough to fit me. Any suggestions?
