Thanks for the feedback guys. I just saw online last night how to spin it without the cover on, that will help.
I installed new points. Today I used a meter to see what the points were doing and found continuity coming and going as I rotated the flywheel. Took the point plate out and cleaned all the mating surfaces and that went away. Going back out in a bit to see if there is spark. I have not shot fuel in through the carb, but with a dry plug after trying to start with and without choke, I suspect something in the carb. I took the carb down and soaked it in carb cleaner, blowing air through it afterwards. Did not have new gaskets,so plan to order some tonight. I will get it or learn a lot in the process. the journey continues.......
