Old atlas royal carb help.
heinzinfeffer
I have an old Atlas royal 5 hp outboard and was wondering where i can get a carb rebuild kit?? Any help would be greatly appreciated!
steelespike
Re: Old atlas royal carb help.
If the motor is like the GHale 5D12,13 ,or 14 or newer it uses a carb kit very similar to the Johnson or Evinrude of those years.
Those motors have pull push type choke with high speed and low speed knobs above one another.with the low speed above.
18-7043 kit should work with a 18-7094 needle and seat.Should be available here at boats.
If older than these you might have to check with the guys at www.aomci.org I think you can webvertise without joining.
