old boat lost its shine
oogaboga
Ive got 1990 bayliner cobra that has lost its top coat so it does not shine ,how and what can i do and use to bring it back,metal flake is still there,but very dull looking.
oogaboga
Re: old boat lost its shine
forgot to add,will car clear coat work or not :confused:
glass from the past
I don't know about the metal flake, so you may want to double check this product. 3M makes a fiberglass wax and restorer, it is a one step product just apply it and buff it out (label says you don't have to buff out, but I got an awesome shine when I buffed mine), I used it with an orbital buffer and it was pretty simple and offered great results.
JasonJ
Get ya some 600 and 1200 grit wet sanding paper, find an inconspicuous spot, and wet sand with plenty of water with 600 and 1200. You would be amazed at how good it looks. If it turns out, then you can do the entire top. Then polish it with a good marine polish and you should be all set. I have achived shine in a boat that is over 30 years old, it had zero shine. Its a ton of work, but the end result is worth it. Any paint would require sanding anyway, so the work would be similar.
kenjudy1
starbrite makes a product thatt does real well.
johnnybigrigger
Dodge.....I will stay off my soapbox from now on, and watch from the sidelines where I belong. <br />JBR @-@
phatmanmike
wet sand , wet sand, wet sand , wet sand... look at my pic, i wet sanded with 600 grit 3m paper, and then used the 3m fiberglass restore & wax, and THEN used starbrights boat fiberglass wax... ill let you guess which is before, and wich is after, and by the way, my boat is a 1960 glasspar, had been sitting outside, in florda for 18years uncovered
<br />
<br /><br />not bad, ehhh. i hope this show EVERY body what can be done with wet sanding, this was my first time trying it, i tried the chemicals alone before this but this is excellent....and oh, i used a sock and it tokk me about 30 mins... imagine what would happen if i really tried and used the right tools... sparkle. sparlke.shine :)
bidlimit
Use 3M fiberglass restorer/wax; the heavy duty stuff. I burned mine in with a right angle polisher and it really brought out the fiberglass. Use a "pro" right angle polisher; it looks like a big angle grinder...Orbitals work OK but can't get the heavy oxidation off. You could probably rent one cheap. I can't say enough about this stuff. Try it before the wet sanding. It worked on my '85 Sea Ray...
