Hi guys, I just picked up an old dinghy from a friend's garage. The boat is old and was stored in pretty bad conditions. It needs some patching up and some valve replacement, but that I think I can handle. I need some advice regarding how to proceed with repairing the transom. It's made of a sandwich of laminated plywood with a solid wood core. The plywood has split from the wood, the wood has started to decay in some places, but to me it doesn't look so bad. I don't think I can handle replacing the transom on my own and would consider this as a last option. Where I live there's no place I can take the boat to have it professionally repaired, so I have to somehow manage it on my own.
I attached some pics of the transom, I was thinking to scrape between the plywood and wooden core and take out as much decayed wood, dirt and other debris, then fill in between the plywood and wood with epoxy, clamp together as tight as possible and pray for the best. Any kind of advice is appreciated, thanks a lot!
