I have a model No. 571.58562 s/n 562.3171.This unit is frozen,it seems almost complete. Anyone with assembly and or parts/repair info would be appreciated before I go in.......
Go to Sears.com and enter your numbers in the parts search. Should be able to get what you need there. There was another post recently about freeing stuck motors that involved soaking the piston tops in diesel or WD-40 and gently tapping on the piston(s) with a block of soft wood and a hammer after pulling the cylinder head. This won't work if the piston is at the top of its travel. Hope this helps!
