old envinrude
fatts2436
i have an older outboard evinrude that says 18 horse. it is blue with words fast trim. can anyone identify the year and how much it may be worth?
JB
Re: old envinrude
Howdy, Fatts.<br /><br />Welcome to iboats. :) <br /><br />My guess is that it says Fast Twin, but we need the model number to give you an accurate answer.<br /><br />The model number will be on a plate on the mounting clamp.
fatts2436
Re: old envinrude
hi jb<br />the model number is 15028 and the engine serial number is 04783<br />thanks,<br />fatts
JB
Re: old envinrude
That's a 1959 18hp, Fatts.<br /><br />Fuel mix should be 24:1 (1 qt TC-W3 outboard oil to 6 gal unleaded regular gas).<br /><br />Spark plugs are Champion J4C gapped at .030".<br /><br />Set the points at .020".<br /><br />Good engine. Good luck. :)
altic05
Re: old envinrude
I have a 25 hp evinrude but I don't know the year, can anyone help. The model # is E25REIE
llfish
Re: old envinrude
Post your question under a new topic. Your question has been answered under a post that you stuck on the end of someones post.
fatts2436
Re: old envinrude
thanks for the info wrote it down. now also i had an older gent work on this motor and he said he but in a mixing valve for the fuel mix connection for a new gas tank do you know anything about this ?
fatts2436
Re: old envinrude
thanks jb<br /><br />when i brought it to this gent , he was very knwledgable and had worked at a lake norman establ for a long time
fatts2436
Re: old envinrude
one more question jb,<br />do you know how much this could be worth?<br /><br />thanks,<br />fatts
