Mid to late 60's evenrude sportwin 9.5 model number is 9522c
Trying to get this thing running. I've rebuilt the entire bottom end. And the electrical system. I get good spark can get it to fire, only one or two "put put" then it quits
The guy I got it from was into the carb and sad to say dosnt seem to know what he was doing.
He supplied me with a carb rebuild kit that wasn't the correct one (or mabey as correct as possable for this old girl)
I can't seem to up load a picture but on the carb there is a tube that runs parallel to the idle adjust valve
Runs along the top of the carb body.
When I pump th he gas bulb I get gas squirt out of this. If I pull it won't fire unless I both choke it and put my thumb over the end of this tube
What is this for? Is there suppose to be something in here that the previous guy removed?
