Old evinrude identification, help please..
johnyfan
Hallo, I just purchased old very small evinrude outboard that needs some parts and maybe even some work...my dad is very handy guy and I believe he will be able to help me w/ it but I don't know anything about this engine so if any of you might know something would be great help, ser. numb. is M 1902C-E03352 motor has compresion, carburateur, and overall looks like it will purr again. It is missing tank and cover and I will probably need those parts in future...problem is I'm quite new in this and could use any help I can get....thanks to all of you
Viktor
ezeke
Re: Old evinrude identification, help please..
1902 goes with a 1969 1.5 Horse Evinrude.
"http://web.archive.org/web/20011214132509/www.evinrude.com/docktalk/modref/evmodyr/EHP1.html"
Check the 1969 1.5HP Evinrude parts manual on the Bombardier Recreational Parts Site and see if it matches .
"http://epc.brp.com/default.aspx?brands=ej&lang=e"
johnyfan
Thanks a lot, I know way more than few min. ago...is it possible to tell how available in general parts are for engines that old ? I will do the search of course but wondering is there a hope for quick fix...thanks again
ezeke
Many routine maintenance parts, try the right side of this page.
For replacement parts, try your local dealers. You can find them by selecting the third circle and entering your zip code here:
"http://dealerlocator.evinrude.com/EN/?
Rnd=1174347249859"
For scarce parts, check here and scroll down for a list of companies:
"http://www.evinrude.com/en-US/About.Us/FAQ/Older.Vintage.Products.htm"
And, if you want to do your own maintenance, get a factory Service Manual like the one listed on Ebay.com.
Just enter 280094546725 in the ebay search window.
johnyfan
Thanks a lot, I purchased catalog of parts few days ago and now waiting to be shiped to me...I am guessing that lot of details about that motor will become clear, but still impatient as I am would greatly apriciate if someone could tell me what kind of cooling sistem it uses ( water or air) and what model of spark plug it takes....thanks much
V.
ezeke
It is water cooled. The water pump is at the top of the gearcase and is powered by the driveshaft.
It runs on the Champion J6C set at .030.
"http://www.boatsetup.com/SparkPlugChart.pdf"
You probably should have bought the factory Service Manual instead, The parts manual is free at the link on the previous responses.
Here is another Service Manual listing:
"http://cgi.ebay.com/ebaymotors/Johnson-1-5-HP-1-5HP-Outboard-Motor-Service-Manual-1969_W0QQitemZ200092675745QQcategoryZ26453QQrdZ1QQssPageNameZWD1VQQcmdZViewItem"
You will probably not find another that cheap.
tashasdaddy
parts also at laingsoutboards.com
