Re: Old gas?
Plug off the vent.<br /><br />Wrap a rag around a blo-gun and pressurise the filler with a psi or two while you fill a container off of the fuel line. <br /><br />Smell like varnish?<br /><br />If so you could set up a siphon fron the 1/4" fuel line to a can below the boat and start that with the rag blogun procedure.<br /><br />If it smells like gas you could add some ( a pint)of Berrymans B-12 or equiv. and top it off with premium to make sure you have some octane. Use it.<br /><br />Check or change filter(s) till you feel secure.
