Calling all marine techs: If you tune motors for a living you must replace lots of impellers. Could one of you please throw the old ones into a box instead of the trash if the customer doesn't want them? If you could put a piece of masking tape on them with the year & make & HP (part #!) that would be great. Once you have a box full put it on eBay clearly stating that they are used and not suitable for repair work. I'll buy 'em.
I'm trying to determine what currently available impellers can be successfully modified to fit old outboards (various makes). I have a bunch of old outboards that need new rubber. It's way too expensive to experiment with new rubber. Once I know what part #'s will work by experimenting with old junk I'll order new and modify to suit. I'll also keep records of what works for what and find someplace to post it. Am I reinventing the wheel here? Has OMCOA already done something like this? Is there a place to find out what currently available impellers can be used as replacements for old outboards with minimum modification? I got some input earlier on another post about fabricating impellers that was very useful. If you've found a suitable replacement for an old model please post it on this link to share with others. Is there any place where manufacturers like Sierra show the inside diameter, outside diameter, and thickness of their impellers? Thanks!
