55'Fleetwin7.5
- Joined
- May 29, 2007
- 241
I took her out today (after repairing the flywheel/crankshaft situation) Started right up... warmed her up... tuned high speed carb adjustment at WOT in gear...Check! Brought it down as low as the throttle cable would allow, again, in gear... Adjusted low speed needle (idled not smooth as silk, but not missing either)... Check!
Now when in neutral, if I bring throttle all the way down, it will be too slow to idle and will stall. Is this normal? I can adjust the cable some to maybe correct this... What is the general rule on that? I would prefer it did not because I am installing a kill switch and will use it to stop engine. Starts right back up though...
Tom
Tom
