rrw
- Joined
- Oct 9, 2011
- 104
Hi there, I just found this forum, there seems to be a lot of knowledge here. I have a 15 ft 1971 starcraft fishing boat with what I believe to be a 1963 Johnson 40 HP outboard , model # RDS-25D, serial #2339179. Couple questions: what is the best spark plug and gap to run for trolling? I'm not a fan of champions and that's what it came with. I run shaefers 2 stroke oil in at 32:1, but it still seems to foul up when running slow, it runs very good mid to wide open. Is it suppose to charge the battery? Because it doesnt, it has electric start, the static battery voltage is the same when its off or on(12.6). Any other info concerning this motor is greatly appreciated.
Thank you, Ryan
Thank you, Ryan
