Ross72
- Joined
- Jun 15, 2009
- 110
Ok, here's the background. Last summer I picked up a hd-25 from what I can tell it's a 2 cylinder 2.5 hp biult between 1946 and 1950. Powerhead is locked up, but lower unit is good along with most of the ignition
Earlier this week, my dad picked up a tn-25 which I believe is a 5 hp twin cylinder built between 1950 and 1951. Dad says it turns over ok and has decent compression.
Dad's cottage is on Pymatuning Lake in Jamestown, PA and we are headed down there Sunday for a week. I have to put a roof on the cottage and the kids are on spring break.
My question do this motors share the same coils, points, etc? I haven't been able to find a parts list online to look at and compare part numbers. I haven't seen the tn-25 yet but dad says it looks pretty good for it's age.
I will check spark, compression and fuel, just wanted to know if there were any diagrams available. Dad wants to stow the motor in his sailboat as a back up, since it has an onboard tank.
Also, is this a 16 to 1 or 24 to 1 mix ratio motor. Thanks in adavance for an advice and or suggestions.
PS. Dad got the motor for $25, so it shouldn't be too expensive even if I have to replace the whole ignition system.
