old johnson........
Droog
I just found a old Johnson outboard motor. Its green and small Im guessing its a 2-4 hp but it doesnt say anywhere on it.It has a recoil starter that was off a laying on the ground next to it and I exspect that was broke and whoever threw it out couldnt get it started and just said the hell with it . the only #s I can find is on the side of the case and it is 570573. What is it?
Paul Moir
Re: old johnson........
That sounds like a casting number, and I can't seem to find any information from it. If you can't find a tag on the transom clamp, check the welsh plug for any numbers. The welsh plug is a silver, convex "core plug" located near the spark plug end of the block.<br /><br />How many cylinders does the outboard have? Could you describe the recoil starter a bit? IE, does it engage the flywheel from the side or the top? Does it resemble an electric starter?<br /><br />I'm sure we can pin this down for you. Green suggests late 60's or 70s. But it depends on the shade. No hope of a picture is there?
Droog
It has a HD 25 on it below the # I looked around a little and I think it is a 2 1/2 HP made between 1946 and 1950.I found a site with a old catalog from 1947 and it has a picture that looks pretty close .The recoil engages from the top.
Droog
Thanks for the link Its a 1947 model. Hope I can get it running If I can I will have to buy a small boat for it .Maybe a 10-12'.
