Old Junk
Yepblaze
I've been having a blast running one or the other lately.
<br /> I have a problem with the throttle control on the Johnson 1958 18hp. If I let go of the twist grip it will slowly 5-10seconds go all the way to the stop position. It would be nice if it stopped in the idle area and didn't have so much spring return.
<br /> <br />Also it's not going full butterfly open I see no way to adjust that. The bushing or whatever in the linkage seems real loose is that it? I did notice just the "drape" of the plug wires makes for some degree of recoil acion.<br />
kev_alaska
Re: Old Junk
I am of absolutely no help to you on the Johnson. The only comment I have is I have that Mercury's twin sitting in my storage shed. I wish the newer ones had as good looking lines as the older ones...<br /><br />Kev_alask***
Bear
Re: Old Junk
Nice engines, nice pictures!<br />The 18HP Johnson looks about the same as my 1966 Johnson 6HP. Had the same problems. First I replaced the worn roller. Mine is smaller. A piece of a new rubber hose works just fine for it. In your case it might be hard to find a rubber hose in that size. But if you find one it will take care of the butterfly problem (not open fully). I guess it is hard to find a new roller, right?<br /><br />I also made a throttle stop to take care of the idle problem. On the 6HP there is a bolt I used to bolt the throttle stop (a piece of aluminium). Can't see a bolt there in your pictures. I could not figure out how it was supposed to work when it was new. There is no friction screw anywhere.
RICKRICK1
Ensign
Re: Old Junk
For your throttle creep problem check out you local motorcycle shop and see if they have a bolt on cruise control. It works with friction and if I remember right there is no drilling as it clamps on.
Reel Appeal
Re: Old Junk
Hi,<br /> Is the throttle tensioner that bolt head I see in the twist grip?? :rolleyes:
