I have acquired a 1960 Merc model 200 22 hp serial number 1341599 motor and it runs perfectly, except the water pump is shot. I have removed the powerhead and the gear housing assmbly. I also removed the pawls and the pawl springs and then pulled the large transmission spring from the bottom of the leg. The small spring and the pump impellor assembly above are still there and I cannot figure how to get them out. I do not have the special merc tools and the merc manual is very poorly written and illustrated. It simply says to push on the drive shaft and the whole thing will come out the bottom. That did not work.<br />What can I do now? please help.<br />Bill K.
