Re: old Sea King 5 stumbling at low speed... oil mix?
Tim,<br /><br />Lake Austin is ok, except the Hydrilla got thru the tom miller dam into town lake now. Travis had 4 gates open for awhile...a pretty cool sight seeing all that water coming out of the dam. still 1 gate open. Travis is around 688 now, down 5-6 feet from its max. It's great to see the lake so full, though the e coli is apparently pretty bad at the moment.<br />Canyon lake/guadalupe got hammered very bad. water was *7 feet* over the spillway, over 80,000 cfs was being poured into the guadalupe, instead of the usual 100-300 cfs the tube riders like to have. the worst Canyon Lake has ever seen.<br /><br />re my motor...do you have a guess at the year? some of the books go pre and post '69 so its age may be important.<br /><br />In looking at the carb it looks pretty tricky doing any work on it with the carb still on the motor. though I see a ?needle valve? on the bottom of the carb under the float bowl. I am tempted to remove it to drain the bowl, but am reluctant to try and remove the bowl itself for fear of the unknown when it opens, considering the cramped nature of the space there. and, worse, most all my hand tools were stolen 2 weeks ago, incl my angle screwdrivers which look necessary to loosen the bowls screws which point straight down.<br /><br />guess I better find a manual soon before I monkey too much with the carb etc.<br /><br />thanks again for all your good advice<br /><br />chuck
