Re: Old Sears outboard identification
Yeppah - It's a 1977 7.5Hp Sears gamefisher. get a load of this;
http://www.searspartsdirect.com/par...47/1305320?pathTaken=&prst=0&shdMod=217585890
The good news is that it's the lightest 7.5hp motor I've ever been able to find. The less than great news is that it uses Tecumseh's world renowned flop of a solid state ignition, which is no longer available. There are some inventive folks here, who have made a study of resurrecting these defunct SSI stators. When you are screwing around with this motor, never turn it over without that plug wire grounded, that can easily barbecue the stator if it's not dead already. If it has a kill switch, I might disconnect it, and use the choke to kill it. If it still has spark, it's probably not gonna be hard to make it go again. If it has no spark, and cleaning up all connections is no help, it's probably still recoverable, but it will be a bit of a process. If you want to take a crack at it, the expertise is readily available. You need to join this crew, too;
groups.yahoo.com/group/eskaoutboards/
