old skeeter deck repair
havaseat
31.jpg16.jpg13.jpg8.jpg3.jpg63/ 13 6 On replacing deck an glass over layer of wood, Basic 3/8 hull outer is solid, I removed deck layer of glass, bases and braces and remnants of layer of exterior plywood vs marine grade I replaced original with 20 plus years ago Original was 2 1/2 inch squares, I went 3x6 bedded in glass resin,, course sanded to outer layer with 1/8 gap between blocks for resin links, Is there better or newer method, The transom @ 1 1/2 or so forward were still solid and doable, Ive lost my large band saw that I ripped blocks square with in 80s so looking for alternative method
Thanks jj
Redoing it as gift for great grandson, rebuilt 64 merc,
lunchbox lowrance, an ol troller
Few direct drive reels@rods an box
# 3 weeks 250 plus hours, couple thousand dollars,
Found its like chips one is not enough ,
Rebuilt/ bored painted 18 Johnson, new lower unit
refabed early Motor guide 111 to 60 ft,# thrust minnikota head,
built trailer, frame tires wheels, bumpers,
wired for 12/24, depth finders, f@r , 2 batteries, small live well.
seats that rise up from 10 inches to 18,
Added built in jet ski fuel tank and cut off valve
Im thru, tired, an sure as hexx don't recommend doing one again
unbelievable how much can go into boat no longer than long rod,
Almost thru, adding stick steer an control by rear seat
Re: old skeeter deck repair
Ayuh,.... Welcome Aboard JJ,... I'll move this to the Restoration forum for ya,....
Lotsa Great info, 'n Help down there,...
Got any Pictures,..?? We Love pictures....
