SteveVT
- Joined
- Jul 31, 2017
- 163
I have three old Evinrude steel tanks with internal bubble fuel gages that I got with my '63 Lark V. They're in good enough condition to use, but they don't seem to have tank vents, unless they were covered up with red paint by the PO. I scraped the fuel cap clean of paint, but I still don't see how they vent, unless you intentionally leave the fuel cap partially open.
So were they supposed to be non-vented?
These were tanks for a vacuum type fuel pump, not a pressurized tank system, I believe. Single line.
Pressure does build up pretty heavy on a sunny day, and I'm wondering what it does to the fuel pump diaphragm, and float valve with that much pressure buildup.
I've already learned the hard way that before disconnecting the fuel line, I have to open the gas cap to relieve pressure or before the quick connect check valve closes there's a quick gas spray.
I did notice that one of the fuel gage hold-down screws is labeled "drain". Not sure what that's for.
So are these tanks correct without vents?
Thanks!
Thanks!
