1981 80 hp, 4 cyl, dual piston PT&T w/ external pump. Fresh water only, stored indoors for several years. All appears to be in good condition, and supposedly worked fine before being stored. I've searched the forum and haven't found anything relating to the following questions:<br /><br />1. Seloc manual recommends testing the tilt motor leads directly to the battery to rule out wiring or switch problems... no joy, just sparks at the battery, no life in the motor. Guess I need a new motor ~$230 from Mastertech. Or, searching Mercury parts online, I come up with a ~$500 part that APPEARS in the photo to be the entire unit: motor, resevoir, solenoids, valve body, hoses, etc. Could that be right? Or just a tremendous markup?? "P/N 92975A32 PUMP KIT-TRIM $503.55" <br /><br />2. I should be able to release the reverse lock valve and tilt the motor by hand, right? If I'm not able to tilt it by hand, are the PT&T pistons likely seized? What else should I be looking at or doing? Am I overlooking something simple (I hope!)<br /><br />3. Quicksilver control question: The neutral lock-out doesn't lock. Is there supposed to be a spring to push the pin back in to lock the shifter in neutral, or is the spring in the neutral lock-out release supposed to do that?<br /><br />Thanks!<br /><br />Dan
