Just finished rebuilding the old style pump, prestolite. I pulled out the pluger, not sure of the tech name its the one that is held in with a drift pin in the lower manifold housing. When I went to reinstall the pluger the o-ring gets nicked on the pin holes, causing a leak. Only leaks when going down but is starting to make me mad have gone through 3 o-rings. Is there a trick to installing this pluger back in.
