Older 140 Suzuki 2 stroke no power
Farina
Hello, checking for a friend, boat starts runs on low power for a short distance, then shuts down,
Any ideas
Thanks
First, welcome aboard
What trouble shooting steps have been done?
From your description we can't answer, only guess
Farina
They have been working on the fuel side, i will check the low oil sensor and temperature as well.
The high pressure fuel pump was questioned, are they a problem with these motors? Just asking
Thanks
99yam40
Could also be a low oil shutdown
never heard of low oil shutting off a motor
read Suzuki had low oil flow, low oil level, low water level in block and over temp that would alarm and restrict RPMs but nothing about shutting off a motor
99yam40
Thanks
easy to monitor pressure to see if that is a problem.
I guess this is an injected motor if it has a high pressure pump.
Not enough fuel in the VST would cause the motor to not run properly and die when there was no fuel to pump.
being that the fuel cools and lubes the pump as it is running, no fuel means it can be damaged if run without cooling and lube
Farina
I will check again on it shutting down, I appreciate your response, I have to look at the motor to see if he used after market parts. OEM is the only way
Thanks
