Re: Older 50hp V4 Johnson
Hi Brian,<br /> If your friend is looking for a vintage motor to run and show off with on Sunday afternoons, then the 50hp isn't a bad choice.<br /><br /> However, if your friend wants a daily runner with turn-key relability, tell him to keep looking.<br /><br /> Those motors are VERY thirsty beasts and can easily swallow 6-gallons of gas in the blink of an eye. Also, parts are getting hard to find for them, particularly lower unit innards. The lower ends were substantial, but their longevity wasn't the best. There's lots of those motors out there minus the gearfoot for that reason.<br /> Also, for power to weight ratio, you can't beat a newer motor in that size range. That motor is a hernia weighting to happen (sorry for the pun). <br /><br /> They do run alright when set up correctly, and have decent stump-pulling power, although they're not neck-snapping quick. They're also fairly simple for a big motor and not hard to work on.<br /> Those are some of the pros and cons - hope it helps...<br />- Scott
