Re: older evinrude would like info
Well this motor is sitting in my garage and I can't stop working on it . I have the compression now up to 105 in each cyl. did a wet compression then rinsed and tried again. I think the rings were stuck from sitting a long time. It will need a new pull rope as this one has a nick in it and after cleaning it up now I will pull the flywheel and check the coils and points. The tiller handle arrow does not line up with the printed tag for start,shift,low, so will have to check that out. Is it possible to change the flywheel and make this an electric start? any helpful hints and info. is appreciated.
