Re: Older Johnson safety switches
they are there to prevent the starter from engaging at anything above a high idle. I have had motors with them working and not. As long as you always have the motor out of gear and the idle down you can get by. They are still available and not that expensive so I would just replace it and make it right.
That is a true statement as related to the motor in question. However, lest somebody with a different model be reading this, on some the mercury switch is also tied in with the vacuum cut-out switch which prevents run-away. To be honest, I'm not sure if that is the case with the 30 or not. If the vacuum switch is mounted on a plastic plate, it is true.
A large majority of motors are running around with neither switch working. That doesn't make it right. In fact, it makes it dangerous in the starting part. Running over another boat, or worse--a person will ruin everybody's day.
