My son has acquired a 1976 Silverline 22VHT with the Mercruiser 188 drive. He has a problem in that whenever he lets the boat sit for more than a day or two, all of the fuel will drain back into the tank including all of the fuel in the carb and all but a little bit of fuel in the bottom of the separator. So the next time he wants to start it is quite a chore. He brought it over yesterday to see if we could fix it.
I'm not sure what the regs were back in 1976, but is "seems" to me like it might be stock. In the attached picture, the part that I cannot name looks like an old-time glass fuel filter, but there is a placard inside that says if there is fuel in it to replace the fuel pump. I am hoping that this is an early version of the fuel line that nowadays runs from the carb back to the fuel pump and is therefore CG approved. Correct???
Anyway, the other thing is that there does not appear to be any sort of check valve in the system. We want to add one but don't really know where the best place to put it would be. I think we will just try to add one in where the fuel line comes out of the tank. I have read that many boats have one located there.
And lastly, any other suggestions to fix this are welcome.
Thanks,
Wayne
Thanks,
Wayne
