Re: Older than dirt Oil question
Holy Guacamole, You guys been having fun without me.<br /><br />Ive been LMAO reading through the above post and all. Thanks Mod 4 for closing it, What took ya so long?<br /><br /><br />Dont use the old oil, there is just no sense in it!<br /><br />Oh, You would have to be out of your mind to go 10,000 Miles on conventional oil!!!
The additive package is nearly completly depleted by about 5,000 with most oils, However the HDDOs (Heavy Duty Diesel Oil), will go to about 7,500.<br /><br />Benlurkin, Yes, you had good service doing this, but there are some late model vehicles, (Toyotas for instance) that are having sludge problems with intervals longer than 3,000 Miles. Its the heat that the newer cars are running that is causing the problems. Synthetics will not slugde under severe heat like a dino will. I use synthetics because I can, not because it is necasary.<br /><br />I do NOT sell oil here, and it would not be tolerated if I did, so BACK OFF!<br /><br />Oh, We dont pump our own gas because its against the law here, (we dont like it either), I DO Know how to do it myself though, and your remarks were WAY off base.<br /><br />OK, Im done, and sorry for hijacking the post.
