I have acquired an older torlling motor, there are no connectors on the two
wires that connect to the battery. A black wire and a white wire, the white wire is a larger diameter than the black wire. The white wire connects to the on/off switch, the black runs down the shaft to the motor. So which is positive and which is negative? Thanks, Old Jim
