OMC 120 ignition coild problem HELP!
timobrien
I have a 4CYL 120 OMC 1977, for many years it has persistently done something similar. It will run for appx. 30-40 minutes then the coil gets very hot, and starts breaking down and if the engine shuts off it will not start back. Numerous times I have changed the coil, points, condensor, and balist-resistor only to have the same problem. Last year i switched to pertronix electronic ignition, and a pertronix coil w/resistor it seemed to run a little longer but the same problem (coil overheating) occurs.
I bought a voltage regulator with an adjustment and adjusted to 13.5-14.5 output problem still persists, i spaced the coil 3 inches from the engine to cool it, i even bypassed the ignition switch but it still occurs.
(i can cool the coil down with ice, and it starts right up and runs great once it cools)
Any suggestions would be helpful!
Reel Poor
Re: OMC 120 ignition coild problem HELP!
What is the voltage at the battery with the engine running at idle?
What is the voltage at the battery with the engine running above idle (2500 rpms) ?
What is the voltage at the coil with the engine running? At idle? At 2500 rpms?
Check the voltage with a hand held volt meter.
