OMC 2.3 Timing
stub756
I have a 1988 OMC 2.3 Cobra. Sometimes while accelerating the engine will back fire or hesitate. I am wondering what should the timing be set at, at idle?
stub756
Re: OMC 2.3 Timing
Anyone? It appears to be at 4 Degrees BTDC right now.
denniz
Re: OMC 2.3 Timing
PATIENCE Stub. timing is 10 btdc. like previously posted. Your hesitation is probably fuel related. Prob. needs a set of points too.
denniz
Re: OMC 2.3 Timing
Wait ill have to check on that(seriously) I think its 10degrees after tdc.
stub756
Re: OMC 2.3 Timing
RD the points and condensors are fresh.... The hesitation is pretty consistent sometimes worse then others. I'm not saying it is the timing id just like to make sure its to spec.
denniz
Re: OMC 2.3 Timing
I wont be able to check till I go back to work tommorro. Doesnt your engine have a tag/ label on the flame arrestor cover that can tell you firing order, plug type and timing etc?
stub756
Re: OMC 2.3 Timing
No tag, label or anything with that info. Need to pick up a manual for this. Just got the boat and all the shops are closed for the holiday weekend. Thanks for checking RK.
clanton
Re: OMC 2.3 Timing
After you set the timimg to specs, recheck it a few times after you run boat in water, if the timing has moved, check the roll pin in the dist drive gear. Dist were replace in some of these engines 88/90, because of dist drive gear silppage.
pingjockey
Re: OMC 2.3 Timing
The firing order is 1-3-4-2 with a timing of 10 deg BTDC at 600-650 RPM. If you still have points the gap should be .018 with a dwell angle of 36 +/- 2.
