This is my first boat and am wondering if its possible to get water in the oil by over-pressuring the cooling system using ear muffs and a garden hose? I read in a service manual that you should not pressurize the cooling system. I did get a milky oil mixture after I did this. I then flushed the oil system with a 2 part mixture of oil, transmission fluid and diesel fuel. I changed the oil and it does'nt appear to be getting and more water in the oil. I changed the way I am using the earmuffs. I have a five gallon bucket and i run the water hose into the bucket then with another hose use a siphoning effect to feed the cooling input fins on the stern drive. This way I now have only gravity pressure on the cooling water. Just to make sure I did'nt have a blown head gasket I did a leak down check on all four cylinders. All were at 10 percent or less leakage.
