Jason Councilman
- Joined
- Aug 20, 2008
- 9
My 2.3L OMC, which I thought was a "tune-up" issue is continuing. I've had the boat running, but got stranded on the lake Sunday afternoon about 300 yards from the dock. It took all but 10 minutes of running for it to die out.
Here's the situation... After the boat gets hot, it will begin mis-firing a little. After a couple more minutes, it dies out. Then it will not start.
If I run a jumper directly from the battery to the + side of the coil, the boat engine runs GREAT. No problems at all.
I've been told that this is a bad starter/key switch. So, I took the same jumper cable and jumped out the key switch. The engine will not run smooth, if it starts at all.
So, the only way I can get the engine to run well is be running the jumper from the battery to the coil.
Is it possible that the starter solenoid is bad and "acts up" after it's hot?
Is there something else I could be missing?
Please help... again.
