freedom170
- Joined
- Aug 1, 2011
- 4
i am at witts end on this one. first some back ground. i bought this boat last year, a 170 freedom 4-winns with aa 2.3L ford motor, omc drive. the first time i took it out it was fine u could pull skiers and all. then the next time i took it out after about 2 hrs when i starting to take off then at about 3000 rpms it would start to miss like a bad plug. so i took it back home and tuned it up( i have been a mechanic for 35 yrs.) plugs wires, cap, rotor, gas filter, points, conds. the works. take it back out it runs fine for half the day then starts it again. i take it back and double ck every thing. dwell timing wire routing.put a nother set of points and conds. same thing. replaced the coil no help. tried a differnt gas tank when it started, no help. alternator, had rebuilt because of a noise bearing so help(didnt think it would but needed it any way.)disconneted wire to tach same problem. rebuilt carb. same thing. it only acts up when its get up to temp and get worse if u keep trying to get going. if u let it set for a hr or so (go swiming or something it run like a new boat and if u stay crusing it keep going but as soon as u slow down to a idle and try to take off it wont go just starts jerking,feel electric but cant find anything. even sprayed it with water in the dark with it running but not uder a load and all was fine. im down to the fuel pump but its 280 bucks and dont want to replace if it not that. the only thing else i can think off it to hook up a fuel pressur gauge and try it. if any body has a clue of whats happening it sure would make the wife happy and as we know keep the happy and we can be happy. thanks dave
