I have a omc 12/24 volt trolling motor 1996. I believe it is 41lbs thrust. My problem is all of a sudden the second speed setting does not work. My first speed (small arrow) works fine on both 12 and 24 volt settings, also the third speed ( large arrow )works fine on both. But the second speed does not work on either. <br />Batteries are good.<br />Wiring from batteries to motor is also good.<br />dont know too much about trolling motors but I am thinking about taking it apart to look for- i'm not really sure, loose switch? bad terminal?<br />Any help or suggestions would be greatly appreciated.
