OK, so i took the drive off the boat and dissassembled the unit in preperation for replaceing the shift cable. the cable had broken right at the pulley assembly on the shift housing. once i had the whole thing apart i wanted to make sure i could shift it from R to N to F by hand. how difficult should it be to go through the shifting sequence? i can get it to go into all three positions, however, it takes a little force. should this be a smooth one finger type of operation if correct or should it take a little force to complete the full range?
1983 omc 3.0 l
engine model 302STHRCTR
engine serial J764983
drive model 982740
drive serial J313762
any advice on this or what to do next would be greatly appreciated as i do not want to reassemble if i might need to do further repairs.
thanks guys
1983 omc 3.0 l
drive model 982740
thanks guys
