OMC 3.0 Point Replacement
Slimmer
This is really crazy and I was wondering if any one else has had this problem. I have replaced about 20 sets of points in my day and never had this problem before. I put new points in my OMC 3.0 gaped them @ .019" NO START! Regaped, NO START! Regaped one more time, NO START! Put old points in, gaped @ .019" Started right up! Bought another set of points and the exact same thing happened!! I have never had bad points off the shelf before. The only differance between the new and old points is (GET THIS) the old set has a little pad with greese that rides on the cam and luberacates it. I know this has nothing to do with it BUT??? Strange Days Indeed!! Any one else heard of this? :confused:
akriverrat
Re: OMC 3.0 Point Replacement
had this problem when they sold me wrong set for application. are these from omc?
Slimmer
Yes, both sets. One set came in a kit with rotor button and condensor.
akriverrat
try gapping to .014? you know they are opening...but are they closing?
Slimmer
Gapped the old ones the exact same way, and they worked. Would there be any differance?
elpaso
Drag a very fine emory cloth through<br />new points - they have a protective<br />coating on them.<br />Very common problem.
elpaso
After emory cloth soak a business card in<br />alcohol and drag through points - removes<br />any oil.
Slimmer
Didn't think of that. Will try (just never had to do that before with new points)Thanks for the tip!!
